1 - 5 of 5 Posts
Has anyone else noticed with the progress anti-roll bar they supply you with grade 5 hardware
? considering what they charge for the bar you would think they would give you grade 8.
Use your OE endlink hardware with the Progress bushings if you are that concerned...
Discussion Starter · #4 ·
It's not as much a matter of concern mostly i was just surprised to see grade 5 replacement hardware when the oem is also grade 5. for that amount of money i think they should've stepped up to the grade 8. just wanted to see if anyone else took notice of that. i'm more than pleased with the bar itself though.
The progress hardware will/should work just fine for you. I had a stripped, fully suspension built 00 zx3 once and would fling it around corners and do lots of hand brake turns.
That car took a ton of abuse. If the hardware was poor, the bolts would have broken by now, etc.
Youll be fine.
Enjoy the new swaybar and go out and do some cornering/hard driving now !
1 - 5 of 5 Posts
