1 - 9 of 9 Posts
I wanting to see if any of you have or would be able to make a new coolant tank for my pwsc. i kinda like how the mustang ones have the nice big opening to add ice if needed plus it allows it to add more coolant to the system. the placement that i was think was where the stock zetec air box was, right over the tranny mount.
who would be up to this task?
Super Moderator
You may be able to make an aftermarket Mustang unit work in that location. You may also want to consider a new dual-pass low temp radiator designed for a Mustang. That would get the inlet and outlet both on the same side as well. This is my approximate plan sometime in the distant future.
I have looked into both. The heat exchanger was the one i was going with. I just dont know if that container will work in that location very well.
Discussion Starter #8
1 - 9 of 9 Posts
