1 - 2 of 2 Posts
It will only work with this intake. It would need modified to use it on a stock intake as well as using a Focus TB on the FR intake.
The FR TB is not simply a direct bolt on to a FR intake and work in the Focus. Modifications need to be made for linkage connections and bracket.
In the book at page 100, they show different set up for the ZETEC.
If you look at config. 8 to 17, you can see that they use the throttle body #M-9926-D462. In page 167, you can find the part number (70MM 4.6L TB)
Does it only work with the FR intake manifold, or it's a simple bolt on with a stock one ???
1 - 2 of 2 Posts
