1 - 4 of 4 Posts
If I buy a stock SVT Header, not the ZETEC kit, I know they don't come with an EGR bung. If I plug the EGR ie. use an EGR plate on the intake mani, will I still pass emissions?
I would be using the SVT Header, Cat and Flex.
Thanks
What sort of inspections rules are there in VA? Visual check for equipment, exhaust sniffer, just an OBD-II check for emissions-related CELs? If you have any kind of visual check for equipment and that EGR system is gone, you will fail. That is, unless the person doing the looking is either stupid, doesn't know what they're looking at, or you've "persuaded" them otherwise.
Discussion Starter #4
The sniff and visual but are moving to the ODBII testing by mid 06.
I think what I am going to do is just get it tested now. Then go and put the SVT stuff on. This will give me two years.
1 - 4 of 4 Posts
