1 - 2 of 2 Posts
I cannot get the radio or CD player to work and clock does not display EXCEPT when I use the 1 HR button feature. I have checked the fuses and they are ok. They radio and clock function properly when I hit the 1 hour button.
Any suggestions to solve this problem? Thanks
The ignition-on wire is broken or otherwise not connecting right.
There's 2 power wires. One gives it power all the time, to keep the clock and channels saved. It also has the main voltage supply and carries the electrical load.
The other power wire is just a sensor that goes live when you turn the car on. That's the one that's broken or has a problem.
1 - 2 of 2 Posts
