1 - 7 of 7 Posts
Here is my time sheet:
Rt---1.018
60---2.474
330--6.892
1/8--10.530
MPH--67.73
1000-13.653
1/4--16.319
MPH--83.88
The weather was cool, I'd say high 70's.
My mods are as follows:
HKS Exhaust/FS 4-1 Race header/FS flex pipe, AEM CAI/65mm TB
Can you guys give me some help on better times. BTW my UDP is in my trunk waiting to be installed.. Thanks
Try getting your 60' down, you should be running faster then that considering foci can run that stock.
okay, i posted my times a few weeks ago and go no responses. i have a similar set up, i have a 4-1 long tube header, cai, 2 piece pulley, kent cam gears, flex pipe, and exhaust. i ran 16.23 @ 82.73mph. i just lack the tb that you got. i know that my car is a 15 sec car. i need to get it dyno tuned. i will give you the same advice that i was given, "get it dyno tuned". but first you are gonna need to get some adj. cam gears.
The proof that you need a dyno tune is in the numbers, you did a 16.23 at 82.7 I hit a 16.3 at 85.4 Your MPHs schould be much higher. Your car will fly after that.
Discussion Starter #6
Hey thanks guys.. I do need to work on my launching and prevent peeling out at the launch. I really felt that I could of hit at least 15.9. I will look into the cam gears, but I don't know what other bolt-ons i need. Maybe a 70mm MAFS? THanks though
What RPM's are you launching at? I know that when I run with the nitrous I have to do one hell of a burn out to make sure that my tires are really sticky so that when I launch with the nitrous on it doesn't slip. I think that you should at least be running a 15.9 with those mods. That's the only problem that I've seen with these cars though. You have to invest quite a bit of money to get them to run good times. I think that they're more suited for the autocross track instead of the strip. It's still fun though to go out there and smoke a civic every now and then
. Work on the trap speeds and launching and you'll be in 15's no problem. It's still not a bad time though
1 - 7 of 7 Posts
