1 - 4 of 4 Posts
instsalling both this weekend anything to look out for, problems concers?
Thanks
if your car has some miles on it you're going to be looking at some rusty bolts on both. make sure you have a breaker bar on hand. other than that they should bolt right on.
good luck
Nate
yep get ready for some rusty bolts...if you've never done anything under the car before. The cat may not line up w/ the EGR tube quite perfectly. Just hook the cat up to the EGR tube first the move it into position to be attached to the header. Have fun
1 - 4 of 4 Posts
