1 - 20 of 36 Posts
You can cut off the little part that bolts to the stock ranger airbox. I used a bandsaw when I did this.
what about the part that seal into the filter??
Originally posted by hotfocus:
the ranger maf is not a direct bolt-on especily on the volant like somebody with a bumpinfocus told me. i bought one today. if i can find another stock maf for a focus i can make it work.
<font size="2" face="Verdana, Arial">The MAF will bolt directly to the stock airbox. I never said it will work 100% with the volant, as you were the one that told me they were exactly the same. I just don't want you thinking I gave you wrong info on purpose, cuz it does bolt right up to the stock box.
Josh
but doesnt the mas unbolt out of the tube?? and then you can put it in the stock/ volant tube??
Which maf and from what vehicle (ranger year) should I get from. I have a 00 zx3 with custom intake and exhaust.
I just install mine (v6 3.0L 2000 ford ranger MAF)
The butt dyno say yes, but the check engine light say no ???
Does I've the wrong year ???
thanks.
From my understanding you cannot use the 3.0 maf it must be from the smaller motor for the maf to not throw a cel....
Do a search the answer is out there.
<font size="2" face="Verdana, Arial">Actually it's the MAF from the 4.0 that's different.
What about the Contour's MAF? It has a Zetec as well...
Originally posted by spankenstein:
I thought the point was to take the MAF element out of the body and place it in the Focus body. That's what mhernande did that showed gains on the dyno.
<font size="2" face="Verdana, Arial">Yup that's what I did and it showed 10whp gain.
So what are the exact models of Rangers that you can use the MAF off of on our cars?
is there any downside to using a ranger maf?
Someone explain this one to me please. I was looking for a ranger maf on parts.com and all the ranger's I saw had a seperate IAT sensor located in the intake tube upstream of the maf. Foci have it built into their maf sensor. You are telling me that you don't get a cel and your car run as good and as smooth as before with a ranger maf and no IAT?
Also, by re-using the same maf housing your not flowing any more air than before, it sounds like what is being acccomplished is a plug-n-play IAT mod.
People, this sounds like a ghetto mod to me. Can someone give a specific part # and be done with it already.
If it works that's cool but if it doesn't lets get rolling. How many people have this on their car? 3
Thanks!
ROB SOLE
I'm not trying to be rude I hope you understand.
1 - 20 of 36 Posts
