1 - 5 of 5 Posts
I have a 2000 Focus SE. When you look at tthe rear of the car, you can see that the tires are closer at the top than at the bottom. I mean a lot closer! The outer tread isn't even touching the road. I can grab the fender and lift up on the car, and the tires straighten out. After a short drive, they are all out of whack again. I've replaced the shocks to no avail. I see no way to adjust this problem. Any suggestions?
x2 or adjustable rear upper control arms to dial out some the negative camber.
1 - 5 of 5 Posts
