Well, someone loosened all my lugnuts last night
and when I was driving, the rear wheel flew off and now I have 2 broken wheel studs on my rear wheel. I need to replace them fast! Help me!
Make sure to replace all 4 studs and not just the 2 broken ones. The other two might not have snapped off but they're almost certainly damaged to some degree. I think that Ford sells the lugs in 4-packs anyways. You'll need to take the rear drum off the car, then it's simply a matter of punching out the old lugs and putting the new ones on. I believe there's instructions somewhere on how to initially torque the new lugs into place, but when I replaced mine I tightened the lugnuts all evenly, waited a few hours then backed them off and re-tightened them, then went for a short drive and backed them off and re-tightened a third time.Well, someone loosened all my lugnuts last nightand when I was driving, the rear wheel flew off and now I have 2 broken wheel studs on my rear wheel. I need to replace them fast! Help me!
Chisel/drill off the lug nut is about your only option.So what happens if you can't get the wheel off I stripped the back of the stud. Oh and I'm blessed with drum in the rear.
How is he going to remove the spindle nut?Take the whole drum/spindle assembly off just like you're doing the rear drum brakes per the FocusHacks instructions except you'll leave the rear wheel attached. Then get on the inside of the lug stud with a cold chisel and knock it off, then punch the stud out from the inside.
