Anybody ever use one?
My wife's 2003 had all the freon leak out over the winter. I only got to attempting to fix it now. I checked to see if there was any pressure left by tweaking the valve... only a smidge. Hissed for 1/2 a second and stopped. So it was pretty much dead flat.
I put one can of Red Tek R12a into the system, and the compressor started working.
http://www.redtek.com/products_refr.html#
I know it's not fully charged yet, but the compressor sounded laboured, or rather, the engine did. So I decided to use this little oil analyzer thingy. You're supposed to use it to vent the low side port and it catches the oil that comes out. None came out. At all. Bone dry.
Anybody know if this is normal?
I remember when I vented my AC on the ZX3, I just purged the high side port, and green oil came spraying out.
I'm assuming I have no oil left at all? I know that my first indication of the AC system leak was I saw green oil on the snow in the driveway.
In combination with all this, I need to find where her car leaked. I noticed that the black foam around the accumulator/drier is soaked with oil I assume it's coming from somewhere around there. Any chance it's the accumulator itself? I can't hear anything leaking out right now.
Does it make sense that... wherever it leaked from, that ALL the oil leaked out?
The compressor was cycling for a few minutes while I figured this all out. How much damage did I do if the oil is empty? The engine sounded laboured when the AC was on, and the compressor... didn't really sound right.
