probably a stupid question but howcome the 07 focus ST dosent have a redline?
There's also the theory that you could float a valve badly if you drive around at the limiter. Has that ever actually happened to anyone?OmniFocus said:With the exception of boneheaded downshifts, the computer will keep you in the safe range.
My absolute honest view and opinion is that this is not true, with all due respect to the notable tuners that don't agree with me.pitchblack23 said:There's also the theory that you could float a valve badly if you drive around at the limiter. Has that ever actually happened to anyone?
6100 is a good idea. Whether or not it's safe, a Duratec with stock cams and intake manifold simply won't make a lot of power near the redline. It's faster to shift lower than that and drop the RPMs back into the fat torque band.David Anderson said:mine sees a 7k 1st gear shift quite often, 2nd and up, about 6100 ish
That little yellow arrow is an indicator for conserving gasoline. If you watch it for a while you will realize that it comes on at different rpms. In my old Escort GT, it came on based on intake manifold vacuum and rpm. In my ST it seems to behave the same way. When it comes on, push a little harder on the accelerator and you will notice it goes out.07STfocus said:after 5000rpm when the shift light comes on "the little yellow arrow" that is the redline. i dont know why they did it that why, beats the hell out of me.
