I did a search and have been looking at the results for an hour, and found nothing.
Does anyone know what all you have to do to remove the rear caliper to get the pads out? There are two bolts that hold the caliper to the bracket and to the knuckle, but there is also a bunch of other stuff the I can't figure out.
Release the ebrake in the car.
Push the ebrake lever on the caliper forward and remove the ebrake cable.
Loosen the bolts you mentioned. You should need a socket and wrench for each one.
The calipers should now be free.
Tap the old pads out.
To get the cylinder to retract you need a tool that fits in the notched in the piston. You then screw the piston in.
Put the new pads on.
reverse above to finish
Related Threads
Ford Focus Forum
3.6M posts
65.7K members
Since 1989
