sounds like the DSI broke. Have you looked at that?
please do it on your own. The hard part is taking the airbox out. Then you dremel a hole into the clip, and screw a screw into it. Your done (unless your motor fried like a few of us have had happen. Then the motor needs to be replaced as well....Thats it![]()
Now to figure out if I should do this on my own.
I need to replace mine, I'm being lazy. But I have a whole slew of stuff I need to work on as well....smurf - did you end up replacing your IMRC too?
dykast - fixing the DSI yourself is pretty easy, even replacing the IMRC (that thing making the "cycling" noise inside the driver's fender) is pretty easy too. Pull out the battery and airbox, remove 3 nuts, unplug, install IMRC and reverse. They're about $90 from FORDSVTPARTS.
