Can you explain a bit more how rear toe works on the focus suspension? Im going to do more reading tonight. My alignment guy gets bent out of shape when I tell him something other than the "factory" .15 out on the rear, but he will do as I request if I push it.
Positive numbers are toe-in. Factory for SVT is 0.08 to 0.23 per side in the rear. Getting closer to zero in the rear will make the rear end come around more easily... oversteer... toe-out in the rear would be a nightmare of instability, with the car jumping from side to side at every bump.
The way the stock rear works is when the outside side collapses due to cornering forces, the arms and flex blade (trailing arms) cause the outside wheel to toe in and negative camber to increase slightly. [Like a running back planting their foot when making a quick direction change to avoid tackle.] It fights against oversteer.
When you stiffen the suspension too much you loose this function, which may be a wanted goal in some applications to help the car rotate instead of plow, but there is a limit. Also, when you lower it too far, so that the LCAs (front or rear) are parallel with the ground, you will increase static negative camber to the max point, so when you turn and collapse the suspension more, you will actually loose negative camber and loose the mechanical handling functions of both ends of the car.
IMO, it's not best-practice to remove ALL compliance from a Focus rear suspension. It has an excellent, driver friendly geometry that can be ruined much easier than improved upon. A little body roll (the kind that's hard to see, but still there) is actually a very good thing on a Focus. A lot of body roll is, of course, not optimum due to enacting too much nanny understeer, and just making the driver uncomfortable. Eliminating almost all body roll compromises all the effectiveness of the Focus' wonderfully engineered suspension, and would be like driving a tubular frame car that weighs half what the Focus does, and needs to be trailered everywhere... will make you go around the course slower than you could otherwise.
For competition, predictability is your best friend, so poly bushings are good, keeping a bit of rear toe (minimal) is good, keeping a bit of front neg toe (out), or zero toe with an LSD, is good... just as much as braking the same amount at the same time and choosing the same gear and apexing at the same point and accelerating with the same determination each time for each corner are all good. Don't try to outguess the engineers who designed the thing. Use the Focus, Luke.
