1 - 2 of 2 Posts
· Registered
You're going to need to give us a little more information than that. Specifically, what it sounds like, when it happens, etc.
If you're certain it's the tire, quickest way to figure it out is to swap out the offending tire/rim with one of the others. If the problem moves with the tire/rim, you found the culprit. If it remains, you know that's not the issue.
1 - 2 of 2 Posts
