1 - 20 of 172 Posts
Well, the time has come... Tomorrow im starting my roll cage in my 2001. Ill use this thread to post updates, costs and pics.
Cost so far:
Tubing-60ft- $361.61=DOM 1.75x.120, i know the wall is thicker but thats all i could get.
Just an exterior shot of my focus at an autocross with the racing slicks and wheels. (sep 13)
Pron Star
Cool I will keep an eye on this thread.
Excellent! Can't wait to see what's involved!
Are you doing the welding and bending yourself?
Discussion Starter #4
yes doing all welding and bending myself, ill have pics and stuff tomorrow hopefully. & also, this thread is mainly so you guys can ask questions and ill try to answer them.. I dont plan on posting a step by step. But ill try to explain what im doing.
first gut the car :thumbup:
Heres my roll cage main hoop jig with the bar and the first bends completed
and here it is after second bends completed
now all i have to do is make the floor mounts and fit
sorry its taking me so long, but i have a messed up knee and back from work so im slowly getting it done
be careful using this type of bender, if it crimps too much in the bends it won't pass scrutineering. take detailed photo's and send them to a scrutineer while you're building your cage, that way you won't run into problems when you show up for your first race.
Discussion Starter #9
i didnt show me filling them with sand. but i did, and also im using .120 wall so crimping really wouldnt matter in this case. if i was using the.95 wall then i would worry about tech inspection. but thank you. do you know the email adress of the nearest scruteneer to georgia?
Discussion Starter #11
tparker said:
What is the full length of the main hoop?
I did mine at 150" so id have a little extra screw up room. But it really all depends on where you mount the main hoop. Im so tall i have to mound the main hoop on the shelf were the rear seat goes, so the hoop is shorter, but i also have to rebuild the floor there with 1/8" steel plate and then reinforce that. If you mount on the floor, id cut it to 150 cuz i had plenty overlap.
Not sure where you are in GA but here is one listed on NASA Rally Sport as a scrutineer. Make sure you read thru the rules and get to know them well, it will help alot when fabricating a cage. "An ounce of prevention..."
Gary D'Abate
363 Spring Crest Rd
Cleveland, GA 30528
Phone 706-219-6447
[email protected]
Plan B Racing said:
what type of bender are you using to make your bends?
Hehehe, this popped in my head.
Sorry to hear about the back, good luck finishing it!
Discussion Starter #14
I regret to inform you that the roll cage build is being put on hold indefinately because of my knees, and i dont have enough time.
again sry
9 and 3 Damnit! 9 AND 3!!!!!!!
mattm2001 said:
The Focus Is back on Baby:hump:, Woot! More pics in a bit!!!
w00t!
Hooray!
Discussion Starter #20
Ok, Ive decided to get a bit more serious on my rally focus, becuase i want to do so many things to this focus it might only be able to run M2. But heres the updates.
First start with a body shell.
Stock wiring harness... Who needs that pffft.. lol
Starting the stich welding
P.S. This will probably turn into a build thread.
1 - 20 of 172 Posts
