1 - 14 of 14 Posts
For anyone that has the Roush Turbo Kit, what kind of spool times are you getting? On an otherwise stock car (stock cams, stock head, stock cat) pushing 6 psi, when does the turbo start to spool, and when is it fully spooled? (approximately)
I have the kit sitting in my house. Its painful to have to look at it everyday knowing that I have to wait a little bit longer before I have time to install it.
Thanks.
If it starts at 3500, when does it hit 6psi?
Thanks for the quick replies. I'm just trying to pass the time until I have enough time over a weekend to install the thing.
The install is pretty straight forward so you shouldn't run into any problems. If you do shoot me a pm and I'll try and get back to you, but you should be fine!
how would you get it to spool up faster would you just need to tune it
Wrap the turbo and downpipe, That will help with your spool up time. I know it helped with mine.... GT28RS in case your wondering
I bought a complete turbo kit, it came with the turbo blanket, turbo heat wrap (6 inch wide heat tape) and a big roll of 1 inch wide heat tape, and metal tie wraps. It came from Thermo Tec it's around $100, it also greatly helps to reduce underhood temps
Here's the LINK to their page
I would love to, but right know I'm back on 56K...... thats what you get for moving into the country
1 - 14 of 14 Posts
