1 - 7 of 7 Posts
I just acquired an MBRP exhaust system with out the rubber hanger that's listed in the instructions. Does anyone have a picture of the hanger? I looked at the local pepboys and there was about a dozen different kind of hangers.
Thanks.
When I installed my MBRP, I didn't even use the rubber hanger. I couldn't figure out where it went. I haven't had any problems without it.
First Off, Good Choice
The only rubber hanger that I am aware of is the one featured in this photo.
I used it to mount the tip and rear portion of the pipe to the rear most bracket.
All the rest used stock hanger position and mounts.
Make sure you have enough clearance in the back as the exhaust comes over the rear suspension components, as it tends to bounce against this portion of the car
If you don't get it just right it will vibration here and will resonate throughout the car driving you insane within a week!
The MBRP is snarly! Love it. Not too intrusive. It is a bit loud right now due to the cats disintegration, but I am about to fix that with a Focus Central High Flow Cat. I would expect that it would be quieter than it is right now which is like NASCAR loud!
Prior to the failure of the cat the tone was diffrent but diffrent in a good way. Have been very happy with the MBRP system.
Current Modifications:
Volant Intake
Focus Sport Street Header
Focus Sport Flex Pipe
Focus Sport Plug Wires
MPRP Exhaust
Focus Central Under Drive Pulleys
Discussion Starter #6
Mine came with 2 center pipes to choose from. One just has a bigger resonator for a quiter sound. I'm going to use that one when I install it.
Originally posted by focuz420:
bLUE - how does the cat-back sound i was told one of the louder ones?
<font size="2" face="Verdana, Arial">
Discussion Starter #7
Blue,
According to the instructions, the hanger is attached to the second pipe(with the muffler), then to the existing hold down bracket mounted to the frame.
Thanks
1 - 7 of 7 Posts
