1 - 4 of 4 Posts
If I install long headers, a cai and a straight pipe on a stock focus, then should I worry about running lean and eventually blowing a gasket? Or a piston?
Not Special Enough
dosent EVERYBODY run lean from idle? I havent seen an A/F plot that dosent start out at 16:1.
Unless the CAI you use places the MAF in a tube that is too large for it, there is no reason that your A/F ratio would change.
1 - 4 of 4 Posts
