...the 10 pound bottle is empty, one supply hose is not installed nor is the final bit of wiring.
Steve says one hour of labor will enable nitrous operation, an act that voids the powertrain warranty but boosts the fun meter from ho-hum to holy cow!
We can't imagine buying the N2O Focus and not using the nitrous, but if that's the case, then there are still the benefits of a Saleen air filter and a Saleen center exhaust. That, and the naturally satisfying power afforded by the all-aluminum, DOHC, four-valve 2.3 Duratec. There is also the Saleen PowerFlash rewrite of the engine management computer that aids power with a cleanup of the ignition and fuel tables where they might need it, along with helping the nitrous operation, we assume.
The remainder of the N2O's powertrain remains stock. One benefit to the 2.3 engine is it is fairly mechanically robust--something of a rarity from the factory these days--so the occaisional hit of joy juice is not going to decimate engine or transaxle longevity.
...With computer-controlled rpm safeguards in place, this Foci's nitrous will not flow until around 3000 rpm and it is automatically shut off about 500 rpm short of redline.
Blah blah blah...
