can you install just a new performance cylinder head while keeping the stock shortblock and have it run fine? Or would be it better to ugrade the short block first?
It depends on what you mean by "life of the engine". Sure it won't break the crank, or ruin the block or the head itself or any of the parts that are not directly involved with combustion, but regardless of how perfect the tune is, you will wear out the wear-parts much faster... rings, bearings/wrist pins, valves.a turbo wont shorten the life of the engine if its tuned right
I don't know if that's necessarily true. A high revving NA engine has to put pretty much the same wear on the rings and bearings as some boost would.It depends on what you mean by "life of the engine". Sure it won't break the crank, or ruin the block or the head itself or any of the parts that are not directly involved with combustion, but regardless of how perfect the tune is, you will wear out the wear-parts much faster... rings, bearings/wrist pins, valves.
It's not so much about friction as much as just force. In the same engine revs will have almost the same effects regardless of how they happen, including engine braking, as long as each is operating with the same engine geometry and tolerances = stock.I don't know if that's necessarily true. A high revving NA engine has to put pretty much the same wear on the rings and bearings as some boost would.
