Status
Not open for further replies.
SMS Fabrication turbo build >>> This thread will be closed until further notice.
19K views 238 replies 40 participants last post by  focusownerskid
As some of you guys may have already seen in the Great Lakes regional section, the guys at SMS were looking for a car to put their Zetec turbo kit on. Happily, I'm the lucky SOB who got in on it in time to be picked. I'll let Drew and Jeff get into most of the specifics, but I wanted to get this thread started as UPS Clause has been to visit me. To handle the extra power SMS recommended I run the Exedy Hyper Single or the new ClutchMaster twin disk. Well, the idea of being one of the 1st people in the US to have the twin disk was just too tempting, so that's the one I went with.
I'll be having it installed by the good people at Super Street Concepts in Zionsville, Indiana. They're doing the work for about half what a ford dealer tried to charge me , so you can't beat that. Should be about $600.
Now, what good is all this power being planned and the massive clutch if all you can do is smokey peg legged burn outs? So.....
The good people at SSC are installing this as well as part of the $600. Luckily\sadly the economy has been so rough SSC will be shutting up shop at the end of the week, so my ZX3 will be one of their last projects.
So, hopefully the end of business tomorrow I will have a bullet proof transmission. Then 500 break-in miles and it's off to Marysville, Michigan to add some fire in the form of SMS' stage 1 turbo kit....Stage 2 if I can talk Drew into it....:bow::bow:
Stay Tuned to this thread for Vids, dyno, pictures, and general excitment. Hopefully some track times and God knows what else!
Save
Re: SMS Fabrication turbo build
cant wait till u have pics/numbers/vids
Save
This thread is going to get updated w/ pictures from our end.
We'll be picking up the car this weekend and the next couple weeks will be designing and fitting our stage one system.
Parts like a;
GT28R aka 2560R
Tial 38mm Wastegate
Tial 50mm BOV
Blow through in 3in Housing
Precision 500hp Intercooler w/ custom endtanks
We are excited to take this on.
:D
IslandFocus said:
What does SMS stand for?
Spoolin Motorsports and Fabrication.
Save
that thing is frickin Sick...Im jealous
Save
Just an FYI, its not coming to Marysville, thats just where im at :)
and yes i so want that clutch :lol: would you mind if i drove it :D :arr: :lol:
Save
Well, you wouldn't want to drive it right at the moment. I got the car back and the LSD and Clutch are installed, however it seems like they buggered up my shift cables during the process. There was a *click* noise shifting to 5th and everything went to jello. Sadly, I no longer have a 2nd or 4th gear at all and all the other gears are pretty hard to find and get into. I hear there's a how to on adjusting those cables in here somewhere and that's going to need to be a major priority project - it's not really safe to drive as it sits so i'll probably work on it tonight.
Now as to initial Clutchmaster Twin Disk feelings - Hopeful, but a bit worried I think is the only way to describe it. I picked the car up and the installer warned me the clutch was very stiff - I got the worrying impression he didn't understand why one would want this on a street car. Now, Clutchmaster claims this clutch has "near stock" pedal feel...UM....No.... At least not right now. I'm hopeful that correcting the shift cables and getting through the break-in period will help out. Maybe it's normal on a twin disk, but having never driven one i'll just give you my perspective and you take from it whatever you want. Here goes:
1st major issue was starting the car. I'm not kidding. I didn't think the clutch could go any further down, but as the car wouldn't start I assumed there must be more room. I lifted myself up off the seat a little and put some body weight into it and low and behold it dropped the extra couple of inches that allowed me to start the car. I may have mentioned it already, but it's STIFF clutch.
Now, here's the weird part where i'll need some people with aftermarket clutch experience to help me out. There is an area high up where the pedal feel isn't too much more than stock. There about an inch worth of friction zone where you can slowly engage the engine for a smooth start. - only having an inch or 2 to work with is going to take some MAJOR adjustment on my part - Anyway, just below this friction zone you can rev the engine out of gear and just above it you're in gear. I'm talking a combined total of a few inches of play encompassing in gear, friction, out of gear. The clutch also "pops"(feeling not a sound) in and out in this area. Now, that's all in the first 6 inches of travel. Everything beyond the initial "out of gear, engine seems to Rev freely" area is where it gets much much much heavier. Is this small area to shift with normal? I mean I can live with only needing to push it all the way to the floor to trigger the starter, but if it's recommended to fully depress the clutch for each shift, i'm going to go out for pro football as a left footed kicker in about a year and DOMINATE the field.
any thoughts?
Save
sounds like your shift cable linkage popped off at the trans, Just under the fuse cover youll find it. Get down there with a flashlight and look for any plastic linkage's hanging out
Save
Well, going fast is never easy. I was working on the shift cables and have gotten some of my gears back when something let go in the clutch. Not sure what, but there's now zero pedal resistance. Guess that's what I get for saying it's too stiff.
Save
I found what was wrong with the clutch. Well, I suppose it could be multiple things, but this is deffinitely the main problem. I don't know when you call it, but if you basically stick your head under your steering wheel and look up at the cluch pedal arm you will see 2 pin switches. I assume these are the relays to let the car know "clutch all the way out" and "clutch all the way in".
Above the "clutch all the way in" pin switch there is a lever with an eye opening at one end which hooks over a nub on the clutch arm. It looks like when you depress the clutch, this white lever is what presses the hydrolic fluid. The twin disk clutch is so stiff this lever has snapped in half. What the hell do you call that part, where do I get it, and how do I replace it?
Save
#15 · (Edited)
you broke the clutch master cylinder? wow.. weird.
thats what its called tho. the clutch master cylinder. they are something like 50~ from the ford dealer.. or is that from steve.. ill find out for ya :lol:
edit, well looks like its 80~. must have went up in price i guess.
It looks like number 4 right?
Save
Yep. There's that damn eye hook. Number 4 it is.
So, is there a heavy duty master cylinder out there? I mean, I just snapped the eye hook in half clutching a grand total of maybe 20 times and I would assume a new master cylinder would come with the same plastic lever\hook. Any metal ones out there?
Save
I broke mine too.
While at the track no less.
While ON the track no less. It acutally busted my pedal (the dowel pin that connects... sheared it right off).
Save
I saw that wilwood kit online today actually, and it's something i'm deffintely considering for the long term. I spoke with drew and fordsvtparts (steve) and they both have commented on possibly reinforcing the stock actuator in the mean time. Epoxy, or metal rods in the side groove with JB Weld... that sort of thing if possible will probably be the short term fix and i'll see how long that lasts before replacing the whole part with the aluminum piece. Thanks for the link. :D:thumbup:
Car is at Ray Skillman Ford right now having the master cylinder replaced - I figure they can do it much faster than I since I still need to have time to break the clutch in and meet up with SMS by saturday. Happily steve told me the list price on all the parts ray skillman will be using so they shouldn't be able to screw me too badly on the work - in theory...
I'll be speaking with clutchmaster tomorrow to find out if my current twin disk clutch idea is how it works. I'm thinking the top section of clutch travel is your general use area, and fully depressed is for staging at the line when you're putting down serious power so nothing slips. I think it works like a tractor's clutch that way...yeah, i'm from indiana. :D :rock: :hump:
Save
#21 · (Edited)
lourenco said:
That CM clutch kit is overkill if unless you are planning to make over 400hp at the wheels. If your goal is for less than 400fwhp, a CM stage 4 would of worked fine for less.
Honestly that was one of my initial concerns that I spoke to drew about. His assurance was I would need, to be safe, either the CM TD or the Exedy Hyper single.Well, when you agree to be a prototype car, you buy what the builders tell you you need. Maybe they've got some big plans eh?
Save
any thoughts?
Hmmm sounds like you are over-stroking the clutch diaphragm. A twin disc should be set up with a clutch pedal stop. It seems you have a high ratio pressure plate in the clutch, which is why it needs considerably less travel to disengage it than a stock one. Chances are you could have already done some damage to the diaphragm spring. Sounds like who ever installed it has no clue what they are doing. I really doubt it is going to be any easier to press the pedal down at all, it probably does hold somewhere in the 600+wtq range you know. I can see you breaking the stock master cylinders very easily with a twin disc.
There is no break in period for a twin disc, you slip it once and its broken in. The floater plates and pressure plate have a precision ground finish and mate instantly. I have never had any luck with clutch master stuff, I had two stg IV clutches from them that held way less than advertised. I'll stick with Tilton.
So the idea with a twin disk you're saying is that there ought to be an artificially enforced stopping point with some sort of stoke limiting piece if I understand you correctly? Would this be traditionally something included with the purchased assembly or some sort of readjusted stock piece?
Also, the top area of travel in the CM clutch is not easier to move than a stock clutch, I didn't want to give that impression. It's simply MUCH MUCH easier to move through than the area of travel beyond\under that initial resistance.
Save
I did call clutchmasters today in order to get clarification on the clutch feel, but when I tried to speak to someone I got a "the mailbox is full, you will now be disconnected from the system" message. So that wasn't particularly helpfull.
Nor have they responded to my e-mail.
Save
Plus, after only 25k miles on my CM stage 4 6-puck clutch (minimal drag use, maybe 10-15 launches total) the damn pressure plate is gonezo. The twin-plate setup is nice, but I prefer the simplicity and reliability of the exedy. I'd be interested to find out what happens with this in the future, I'll be watching.
Save
Yep, just found this which discusses installing the exact clutch I have -
http://www.theoldone.com/articles/badtothebone/
A clutch pedal stop is apparently something you're supposed to use. People need to include this kind of information in the * vicious swear here* box or something! :mad::mad:. No wonder the master cylinder gave up. Hopefully nothing's buggered and the snapping actuator cushioned the transmission. Now I know to depress only 6 inches to shift. In answer then , the twin disk is NOT a heavy clutch, just very very grabby\short.
Mr. Drew, want to add a clutch stop point to my build? :thumbup:
Save
Status
You have insufficient privileges to reply here.
