I am purchasing snow performace water injection system from ebay, I have been talking with them extensivly about there system compared to the Aquamist 1s. I know I know Aquamist is great etc... but the price is high and want to see what else is out there for us. I will let everyone know the results.
Discussion Starter · #3 ·
I will check it out and get back to you, go on ebay and type in water injection and look for their kit.
Discussion Starter · #4 ·
Ther are two pumps a 60PSI pump and a 100PSI pump, I think I am going with the stage 2 kit still cheaper then aquamist stage 1. This is a controlled kit.
According to aquamist's distributor that I talked to, the Aquamist uses a variable pressure pump, which peaks at well over 200psi. Just something to think about -- I considered the snow units too but the difference is too much for me so I am saving up for the aquamist.
Jeffn Don't just base your decision on PSI alone, as it's based on the orifice dia and the pump capacity ,consider the pump Volume in gph . The two effectand affect each other. The smaller the jet opening the higher the pressure, but not necessarily the same flow rate.
