OK, so let's see - gotta leave it in neutral, and also have to somehow defeat the clutch switch that requires the clutch pedal to be depressed in order for the starter to crank...now, is that the same switch that disengages the cruise when you hit the clutch, and will I lose that functionality? What other hoops do I have to jump through? I see lots of remote-started cars with destroyed wiper drives, because the owner left them on when the car was shut off - and there was half an inch of ice on the car when it was remote-started. Car runs rich for too long, too, when it's started and left to idle.
No, thanks. I have never seen a car that heats up as fast as this one does, and also I have heated seats and a block heater, which I intend to use.
