Ok update. This weekend wasn't a highlight. Motor ran great, first lap and the Pcv hose routing kinked, pressurized the crankcase and dipstick blew out with about a half a quart of oil, black flagged as i made a mosquito fogger proud. No qualifying time, start dead last. Oh boy. 32nd starting position. Great start at vir, my crew guy on the radio tells me green and away we go, passed 9 cars before turn one. My word it was a thing of beauty. By the end of lap one 14 positions and I am rolling, end of lap 2 I see and pull even with 4 th in my class. Oh then there is the **** that racing brings. My car is equipped with a fully functional dash cause the factory builds good stuff. We piggy backed an AIM data system which is attached to the steering column. Lights up, warning, high temp, factory gauge for temp pinned full hot, aim system lights up 240 degrees, both fans are on and the mechanical gauge is only 200, normal for my motors. Ecu goes to limp mode, into the pits, race over. Reset computer with powering all systems off. Restart back out for an expensive test session. Car feels good. New front end setup seems to be working, rear brake lock up still but what is going on. Two more laps and now on off throttle checks losing or getting low oil pressure readings, this day is done. Pit review we found the head temp sensor had a cut wire which we never would have looked for under the shielding, which is directly related to putting the car into limp home mode, one issue we think we found, low oil pressure, I don't know but looking at the cam journal I think I may be screwed, not pretty, so lower teardown autopsy will be tomorrow. Boy not like last year but its a learning curve and I race cause that first lap was amazing and when its all right look out for a four door focus
