1 - 3 of 3 Posts
i was just woundering if anyone could tell me where the speed sensor was located and what it looked like? also is it a push in sensor or a screw in sensor(sensor its self, not wire harness)? any help would be greatly appreciated.
Its behind each rotor at each corner. You'll see a little tab with a 7mm bolt holding it in. Careful, they break EASY. You have to nudge that sucker out a tiny bit at a time...I reccomend a lot of soaking with WD40.
Discussion Starter · #3 ·
Well, thanks for the guys. It turned out that the shop I took it to didn't hook back up the sensor. Took it back in and let them look it over and found out that it was unpluged... We pluged it back in and works fine now... Agin. thanks for the help guys.
1 - 3 of 3 Posts
