Anyone help I have st170 headlights been on a few different focus's of mine and never had a problem with them not working but now i want to put on my 1.8 and they dont work on low beam but everything else works and bulb working ok just the plug was told I had to move a pin from the original connector on car to different slot in the headlight any help to which number I have to moveThe ford jumper wire is so you can have a plug and play set up with your factory wiring connector.
I built a set of these VW/Ford harness for when the Mach HID's were so cheap, but then I could never get a set that was not broken and I had to give up on the HID's. A few months later I bought the ST 170 kit from BAT (which includes the VW plugs/wires of course) so now I have extra VW plugs and wires with instructions...
I'll sell them to you cheap if you want them.
PM me![]()
I am not sure how yours are currently wired up (since mine is a US spec car with a different harness), but here is how the ST170s and facelift lights are wired (ignore the bottom part for your car):Anyone help I have st170 headlights been on a few different focus's of mine and never had a problem with them not working but now i want to put on my 1.8 and they dont work on low beam but everything else works and bulb working ok just the plug was told I had to move a pin from the original connector on car to different slot in the headlight any help to which number I have to move
