1 - 4 of 4 Posts
Steeda 2012 Focus Adjustable Front Swaybar Endlinks - $99.95
Please let me know if I can help you with this.
Steeda's adjustable swaybar end links make a great upgrade for the stock end links as well as the perfect dual purpose street/open track piece.
For street applications these endlinks are as quiet as the factory units. They will not add NVH like rod end units.
For competition uses our double adjustable design makes it adjustable on the car and allows to both retain proper swarbar geometry on lowered cars and adjust swaybar preload for fine tuning.
The adjustment body is constructed from lightweight aerospace grade aluminum and is corrosion resistant. End links feature case hardened ball studs that are greaseable and feature significantly increased swing area compared to spherical rod ends. Includes locking hardware for installation.
Product Benefits
  • As silent as factory units in street use.
  • Aerospace grade aluminum center adjusters
  • Double adjustable design for adjustment without removing them from the vehicle.
  • More swing area than endlinks with spherical rod ends
  • Case hardened ball stud
  • Proudly made in the USA!
Oooh. Me likey.
1 - 4 of 4 Posts
