1 - 16 of 16 Posts
Well its finally ready for purchase
Here is a link to their site
http://www.steedafocus.com/parts/2012-up-focus-short-throw-shifter.html
Here is a picture of the shifter installed
If you use it on the shorts throw you will need to do some trimming, not too bad though
To install the bracket you have to pop of the linkage here
And this is what it looks like with the bracket on
More pics are available apon request
At long last. Not bad pricing, either.
Discussion Starter #4
Wire snips where used for the trimming lol. Also maybe an 1/8th inch if that was trimmed to use the shortest setting
Sent from my SGH-I777 using Tapatalk 2
After trimming, did you have any difficulty putting the trim bits back together?
Discussion Starter #7
No issues at all putting everything back together
Put one of these in my car, quality is great. The shifter itself is pretty easy with 2 people. The bracket on the other hand gave me some trouble. I had to take the battery out, not sure how people did it without but im impressed they did.
I noticed that when putting my in first it feels secure in gear but it makes a different sound then the other gears. Anyone notice this? I dont think anythings wrong if anything i just need to make an adjustment.
I've installed a couple of the brackets, and I wouldn't attempt it without removing the battery...
Mine doesn't sound different shifting to first, though I did adjust the shift linkage right after I was done installing the bracket. You might need to adjust it toward 5th gear slightly to give you a little more room for 1st. Hope that makes sense.
Thanks Tbone
Not sure exactly what your talking about but I have an idea. I havent looked around at the adjustment capabilities of the shifter. Definitely will be looking at that though.
To be more specific, there is a plastic "button" on one of the linkages. You can clearly see the orange button in the pictures above on the trans end of one of the linkages. If you press this buttons, you can shorten and lengthen that linkage to adjust the lateral (left to right) position of the shifter. If the shift gates for 1-2 are a bit crowded, you can adjust the shifter to the right, and likewise if 5th and reverse are crowded, you can adjust the shifter position back to the left.
1 - 16 of 16 Posts
