1 - 4 of 4 Posts
hey i was on the highway coming home doing about 70 mph and when i stepped on the brake the steering wheels shook pretty bad and the brake pedal kind of pulsated but it only does it around 70 mph, the car doesnt pull left or right either. anyone else had this problem and what do you guys think it could be?
your rotors are warped. if you have enough surface, you can get them turned. if not, you need new rotors.
In addition to warping, if you recently got pads, if the pad material was unevenly distributed on the rotor surface it can cause the same problem. See below link for more info on this:
http://www.stoptech.com/whitepapers/warped_rotors_myth.htm
[email protected]
Performance Specialist
Moderator www.focaljet.com To place an order please call 888 541 1777 Ext. 622 or for internet orders through www.tirerack.com/a.jsp?a=DG2&url=index.jsp please mention my name in the previous contact field directly above the Place Order button on the Order Summary page for quick, efficient & professional service.
1 - 4 of 4 Posts
