suspension question
352 Views 4 Replies 3 Participants Last post by  the_enemy_within
I am contemplating dropping my car 1.5 inches, will this mess with the race header I have on it? If so any reccomendations?
thanks,
1 - 5 of 5 Posts
anyone have any ideas?
does the header hang any lower than the stock exhaust? i don't see y it would... measure the distance from the lowest point to the ground, then subtract 1.5" and see how close it would be...
If you have a 4-2-1 like a FC, I don't think you will have a problem. I have had some customers with the 4-1 that have dented the tubes becasue they are a little lower than the 4-2-1.
It really depends on how and where you drive and how good your luck is.
I hope this helps.
Tony D
thanks for you answer Tony.
the main reason i was concerned is i dont want to hit a bump and mess up the head in any way. also i have the 4-2-1 header.
thanks again,
1 - 5 of 5 Posts
