For the sake of argument lets consider this a track car or a car that will be driven in Kansas which has a lower standard on emmisions requlation.
I have started this project already. Some photos can be found here.
http://journals.aol.com/johnstranahanb/RebarrelingandHome-ShopMachining/#Entry1633
More photos in the second topic just below that one in my Journal.
The plan is for an intake system similar to those found on race cars using this 2.3 L Duratec Motor. Horse Power plans are modest 200 -225 HP at the engine, but naturaly aspirated horsepower for good throttle control on an autocross course or road coarse. These gains may not be realized until a full exhaust is available. Stock Pistons and Crank will be used. Now my plans are to also meet current emissions test except for the visual inspection. My plans for this thread are to gain some knowhow in the areas that My nephew James and Myself (John) are lacking. We do have some schematics and wiring diagrams available and some sketchy information on the function of the various tuning motors on the stock intake manifold. Here are some questions to start with.
I plan to inject EGR through a copper manifold. (I know that a pure race car would just omit EGR). The ouput out of the head is a EGR tube that threads into the right front of the head about 4 inches long by 5/8 inch diameter. From the engine schematic it looks like this tube may be water cooled out of a curved oblong port in the head. I would need to deal with this. Does water come out of the head there and then where does it go. Does it heat the intake manifold and return to the area between the two, center, intake ports. If you have had your intake manifold off you probably know this. Mine is not off yet. I am looking to buy or have a stock manifold donated for the project. Once I have the used manifold in hand a lot of my questions will be answered.
The suzuki throttle bodies have a secondary throttle plate that is used on the motorcycle to keep up the intake air velocity at lower RPM's. I plan to actuate these possibly with the Ford OEM runner control that opens at 3000 RPM. Does anyone know if this opens sudenly or gradually. Some test on the engine itself will tell. I am not to this point yet. The Suzuki 42 mm throttle bodies may be a tad on the large size but the secondaries could be adjusted to not open fully.
I have made an idle air manifold that will be fed by a stock Idle air control motor.
John
John
