1 - 2 of 2 Posts
Long time member trying to resurrect a zx3 after more then 15 years in storage. I bought a donor 02 svt few months ago and long story short i am starting front and rear brake swap from the svt to my 01 zx3 with rear drums and no abs.
what is everyone doing with the abs sensor on the svt knuckles when swapping to non abs car? Simply plug it off or should i swap the wheel bearings as possibly they are different and i should swap out the magnetic bearing because of the sensor for one that isnt.
also from my digging here seems as though the front ends are the same other then knuckles rotors calipers is this correct? So control arms front sway bar tie rods all identical for 00-04’s up front?
thanks in advance for any help!
1 - 2 of 2 Posts
