Yeah, I think it was a design flaw on Eibachs part -not- to incorporate those. At least they have an alternative to keeping the bars in place now though.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Why did Jackson Racing replace the stock front sway bar with the Eibach Sway Bar if it is the same thickness as the stock SVT front sway bar?<hr></blockquote>
Good question. Didn't catch that before. Probably just marketing. Afterall, the point of the car was to show some mod potential, and the rear bar is afterall a different diameter. I think you are right and they could have just left it off though (I would have).
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>The SVT rear bar is approximately equal to a 23.5-24mm aftermarket bar (I pulled those numbers from my butt, but I'll bet I'm pretty darn close). <hr></blockquote>
Not really related, but just for those wondering. Each mm bar increase makes a huge difference in the spring rate (if they call it that for twisting bars):
The formula:
R= [pi (G) (d^4)] / [50 (b^2) (L)]
where R is the roll rate in pounds per inch, pi is 3.14, G is the modulus of the material which in the case of anti-roll bar material is 11,500,000, d is the diameter of the bar, 50 is a constant, b is the length of the anti-roll bar arm measured from center to center, and L is the length of the anti-roll bar. (no I didn't remember that, its copied and pasted hehe)
Since we are keeping the shape and material the same we can see that the spring rate (or I guess they call it roll rate) is to the
4th power.
So a 24mm bar would be about 170% stiffer than a 21mm bar (and the Eibach rear bar is a whopping 200% stiffer than the SVT's so one should definitely notice a difference). Thats why I was saying I doubt a little soft rubber could achieve that massive of a difference considering you could probably deflect it by hand. BTW, the bars are obviously related to the spring rates too, so comparisons need to be with the same car and just different bars. ZX3 with Eibach bars would probably feel a little different than a SVT with Eibach bars. Not to mention that the dampening rates would make a difference too (especially if they are different front to rear).
To make it really simple though, if you take an SVT and put on the Eibach rear sway bar and leave everything else alone, it should become considerably more tail-happy as well as reducing roll somewhat.
[ 04-28-2002: Message edited by: Ducman69 ]</p>
