My friend with a SVTnone jet member)has a new fly wheel and clutch put in recently. The problem begain before he even had the work done but after he had the work done the problem seamed to get worse. here is the problem. when ever he gets on his car and shifts into 2'nd gear it doesn seam to go into 2'nd gear.. now remember this happenes either on or before the rev limiter. but when he does he cant seam to get it into 2'nd, but when he is daily driving it and not on the throttle 100% it works perfectly fine.. were not exactly of what could be the problem but ever since the clutch and flywheel..he believes the problem got worse.
ne ideas?
Andrew
ne ideas?
Andrew
