1 - 5 of 5 Posts
I am selling my car b4 oct....so I have a few Q? about what is needed to swap heads/cams
I have the gude stinger pkg.
Please don't flame! over 80,000 miles and other than some valve clatter, ain't nuthin wrong with it
Just want to know besides head gaskets/bolts, what is needed....I.E buckets/shims/tappets
I had someone else install it in 2002 so I ain't an expert as to what is involved in the process?
We have access to tools and wrench hands, so no info on work is neeeded, just what new ish should be used
Thanks FJ members
Yes...The head/cams are going from my car to his car
You'll need head bolts, gasket, engine fluids, and if the cams are going with the head leave the buckets were they are at and they will be set for the other engine. I'm assuming your putting his stock head on your car so you'll need the same thing for both cars. good luck.
BUMP!
1 - 5 of 5 Posts
