1 - 5 of 5 Posts
Sir Buffs A LOT
Okay, tomorrow I am installing the final component to my SVT suspension, the rear sway bar. Any tricks of the trade, anything special I should know about. Looks pretty much cut & dried from the instructions. Thanks in advance.
Overtightening swaybars can result in broken rear control arms. Usually this only applies to the extra-large size, 22mm and above, i would think.
So make sure to tighten the endlinks (the bolts with tons of stacked bushings) to 11 ft/lbs. Basically hand-tighten.
Also Use plentiful amounts of the lube in the tube. Mine came with some (progress rsb). I need to add more because I swear that's where the sqeaking is coming from. Right on the D-brackets.
nevermind about the broken rear control arms, those were only few instances where Some hard-core track moneys were behind the wheel.
One I recall... the rear control arm snapped when launching from a green light... So, disregard what I said about that.
someone can correct me if my 11 ft/lbs torque spec is off.
Otherwise, It's pretty much a 45-minute or less install time
Yeah...
Just jack up the rear of the car...
Undo the sway bar endlinks...
Undo the 4 bolts for the sway bar bushings/brackets...
& then bolt your new sway bar on
Ho, ho, ho... Green Giant
if you're replacing the bushings with urethane components, be sure to lube them to get rid of the squeaking. other than that, this is a pretty easy install.
Mike
1 - 5 of 5 Posts
