Sorry don't have any outer dimensions of the compressor handy here.
T04E compressor outlet is 2" / compressor inlet is 2.75"
I can measure the housing tonight and post up the info.
The main difference is in the flow capacity between the two. T04E compressors have more trim choices. I would opt for a T04E over a T04B anyday.
These are Garrett specs, any afterworked turbo may slightly differ from these. Use as a guideline.
Common T04B compressors:
S trim (37 lb/min)
V trim (48 lb/min)
H trim (49 lb/min)
Common T04E compressors:
40 trim (36 lbs/min)
46 trim (41 lbs/min)
50 trim (47 lbs/min)
54 trim (45 lbs/min -- note that the 54 trim flows less than the 50 trim)
57 trim (49 lbs/min)
60 trim (50 lbs/min)
A 57 or 60 trim T04E is a good compressor, but you have to mate it with the correct a/r turbine housing for your application.
Hope that helps some.............
S trim (37 lb/min)
V trim (48 lb/min)
H trim (49 lb/min)
