1 - 5 of 5 Posts
no...just run the tach signal wire to pin #48 of the computer harness. That hole is empty in the connector. All you do is shove the wire up into that empty hole.
I think
So any aftermarket tach should work then right? And what do you guys reccomend for our spi's. I have an auto so I don't think I need the shift light right?
any aftermarket tach will do. I got a cheapo 2 1/4 tach from walmart for around 20$
Why not just swap clusters? To me there is nothing uglier than a huge tach in the window. The cluster is a plug and play set up.
1 - 5 of 5 Posts
