1 - 10 of 10 Posts
Coo... small amount tho?
$7,405.83?
Discussion Starter #4
$7,405.83?
Ohh, lol I can see how it might look like that... keep in mind that 7400 dollars is how much I paid to FoMoCo since I signed for the car July 4th, 2002. They also paid the other 19,000 dollars back to Chase manhatten, who financed the deal.
Andrew
Discussion Starter #7
Originally posted by BlueSVT2911:
You might want to edit some of that info out
Like what? My name that everybody knows? The check number and routing number of the check that has already been cashed? The first four of my VIN that millions of other cars share?
Andrew
Andrew
If you're cool with it then fine. Honestly I wouldn't want any of my personal information (including my name) on the internet for tons of people who you don't know at all to view. There are some strange people out there man.
Discussion Starter #9
Originally posted by icemanZX3
why did u have it lemoned in the first place??
From back in November:
Originally posted by andrew d b:
Well, i have had my car in the shop SEVERAL times, i am having the following probs with my svt... anyone else experienceing these issues? kinda worried......
Noise from in front of firewall when gas is applied
Stalls when slowing down at stoplight
Poor gas mileage (10-12 mpg)
Unusual noise from engine compartment (knocking)
"Stumble" at about 2200 rpm's in 4th gear
When cold, engine wants to die in right-hand turns
Did not have driver's side rocker sill cover
Did not have rear seat torx bolt covers
Throttle gets stuck when engine is cold
Car stalls and backfires badly when first turned on
A/C is leaking. HUGE puddle on passenger side
Will not shift into 2nd at higher RPMs
Will not shift out of 1st gear at some times (even when clutch is depressed)
Brake squeal
Oil around #1? #4? Spark plug
Speakers in the rear crackle
Loose steering-column mounted colume control
andrew
And the whole convoluted thread here:
http://www.focaljet.com/ubbthreads/showflat.php?Cat=&Board=UBB36&Number=231980&page=&view=&sb=5&o=&fpart=1&vc=1
Andrew
1 - 10 of 10 Posts
