1 - 4 of 4 Posts
I need to replace the housing, seems simple but what should i make shure i do, any advice from someone who has replaced it would help. Thanks
it is easy it doesnt even have a gasket to crape. just make sure that you dont tighten up one side befor the other or the plastic will brake. tighten it up evenly as you go.
and dont tighten too tight, the aluminum head is soft, you can easily mes up the thread, and make sure you line the bolts up right, or you also will mes the thread up
be careful with the hoses, dont puncture them with a screw driver or something
Discussion Starter #4
thanks for all the info, replaced it and its fine.
1 - 4 of 4 Posts
