has anyone done the kit?
is it worth the handling difference?
Eibach pro-system offers more performance than the svt suspension ...not just for looks. ride quality is not bad either even on bumpy roads.Has anyone done it????
Read this thread. http://www.focaljet.com/ubbthreads/showflat.php?Cat=&Board=UBB3&Number=58913&page=2&view=collapsed&sb=5&o=&fpart=1
I'd recommend it over the Eibach for performance and comfort, and the Eibach for looks.
good budget suspension ...YES, night and day difference ...that's a bit much IMO.1) The SVT is an excellent budget suspension upgrade, and indeed is a night and day difference from standard ZX3 parts, especially if you include the rear bar. The SVT shocks are a must as well.
if you're talking about the EIBACH sportline springs than yes the drop is much lower than the SVT and spring rate is very mild for that big of a drop but if you're talking about EIBACH pro-kit (wich i was reffering to) the drop is 0.75" lower than the SVT, not a big difference but just enough to notice a better center of gravity and better looks + the spring rates of the pro-kits are a tad bit higher than the sportlines and SVT wich makes it a better performance spring while still maintaining a great ride quality. yes dampers are a must and the package costs more, but in revenge it is also worth every extra penny spent.2) The Eibach spring sit much lower than the SVT setup, with fairly mild spring rates.. not the best combo for high performance, but probably provides a decent ride. This will require upgraded dampers, which pushes the price far beyond that of the entire SVT suspension setup. I'm not a fan of the Eibachs, but others are, so I'll let it be.
i agree this seems to low and harsh for what you want.3) The H&R cup kit is significantly more expensive than the SVT setup, as it includes springs and matched dampers. It is also very low (-2.5") which poses other concerns as well as a much decreased ride quality from the SVT setup.
i also agree with this ...put your priorities in order and check out what you want. but i still have to say i recommend the eibach pro system since you seem to have the same kind of expectations i had when looking for my set-upSo: If your goals are:
1) Modest lowering
2) Budget
3) Well balanced setup
...then the SVT suspension is wonderful.
Every suspension has pros and cons, let us know what your goals are, and we can make suggestions to fit. The SVT setup might be ideal for your situation.
Apparently my butt-o-meter is calibrated differently from yours... That's cool.good budget suspension ...YES, night and day difference ...that's a bit much IMO.
This is exactly my point... the other way around: .75" is significant. The SVT suspension is roughly .75" lower than stock ZX3 ride height. What does that mean? That means that the Eibach springs are double the lowering of the SVT suspension. 100% is a big difference. That's also double the loss of shock travel.if you're talking about EIBACH pro-kit (wich i was reffering to) the drop is 0.75" lower than the SVT, not a big difference
well if you like at it like that of course it's a big difference but i think the stock ZX3 suspension is just too high to be happy with the SVT 0.75" drop, then again that could just be me ...here's a pic of my Eibach pro-system as you can see this is not low at all.This is exactly my point... the other way around: .75" is significant. The SVT suspension is roughly .75" lower than stock ZX3 ride height. What does that mean? That means that the Eibach springs are double the lowering of the SVT suspension. 100% is a big difference. That's also double the loss of shock travel.
i said it before and i'll say it again, i agree 120% with you on this. have to put the priorities in order, budget, performance, looks, ride quality ....everyone is different and some people might be happy with the SVT kit, it's a good kit i'm not dissing but it wasn't for me and it might not be for him, again just offering some alternatives so he can figure out for himself what his priorities are.I feel the proper way to handle this situation is to present what the SVT suspension will do, and let the customer decide if it is for him or not. Only AFTER that do you make suggestions. Too often the suspension forum is like a used car lot... "buy this, you'll love it!". I don't like that.
I agree with Mike.Has anyone done it????
i know sportlines are progressive and it has a 262/171 spring rate when compressed but the problem is, it is too low to be so soft when they are not compressed and tend to bottom out easily wich is no good, ask anyone who has tried both and they will tell you this : sportline = looks and pro-kit = performance.what r u talking about, the sportline, has a progressive rate of 262 in the front and 171 in the rear, under hard cornering... How is that not a high spring rate??
That deff seems like the better system, because u get the soft ride under normal driving, and all the performance u want under hard cornering.
We REALLY need to make a nice, informative, sticky regarding ALL-YOU-NEED-TO-KNOW when it comes to the SVT suspension swap.
In the last week or two I sware I've seen 5+ posts regarding the subject "SVT suspension".
With so many people wanting it for it's great balance of performance and cost, I'd say it deserves a sticky.
C'mon jptech!
--Dan.
Not really.i understand u might bottom out easier, but with a higher spring rate wouldn't the sportlines perform better than the pro??
No, not quite; Progressive does not mean 'unpredictable.' Any manufacturer who produces an 'unpredictable' spring should be promptly chucked out of the business. I would think that a company with Eibach's experience and reputation would make a progressive spring that is safe and predictable.The reason is b/c they are Progressive...
The problem w/ this is that, they can be unpredictable. Set spring rate springs will always be 200# or 150# or 300# no matter what kind of force is acting upon them, making the car quicker in teh corners b/c U don't have to worry about not predicting what your suspension is gona do next.
Yes this is true, thank you for fixing my mistakes in describing the springs.Gotta be careful what you say and how...
Get it from www.mcnewsautomotive.com and you'll be paying $245. That includes: Springs, Dampeners, AND a 21mm swaybar. It's the ENTIRE SVT suspension.I'm in the market for a suspension kit as well (springs and dampers). So at $275 does the SVT kit have the dampers to match? If so I don't think I could pass it up. I was gonna get the eibach pro-kit bc I honestly did want a lil more drop, but the SVT's ride height looks fine anyway, esp with the 17s. Unfortunately I've never drove or rode in an SVT so I have no idea what I'm gettin into, but it sounds like somethin I want. So again, the SVT kit at $275 is springs/dampers right? and how much is the bar? I've never done anything suspension related before, is it do-able for a first timer? What tools would I need? Should I have a shop do it? Thanks![]()
Or, if you know those specs, any competent alignment shop can do it for you.There really isn't too much "settling time" needed and you can have them set it to SVT specs at a dealership.
