1 - 1 of 1 Posts
Well I have a FC Throttle Body that I have had on for a while (around 20,000) miles. A couple of months ago my idle started reving high when I came to a stop and then slowly work down to 1000 like it is supposed to.
I replaced the TPS and it fixed the problem after I checked to make sure there are no leaks. The car has been running fine until I went through a bad rain storm this week and now has the same symptoms.
I am thinking some water might have got to the sensor b/c the sensor doesn't fit snug to the throttle body. Looking to see if anyone else is having this problem or has a solution, my first TPS lasted 105,000 miles.
Thanks,
Andrew
1 - 1 of 1 Posts
