1 - 17 of 17 Posts
instead of doing the pennies/nut thing... (it never worked for me... kept coming loose and throwing a code) I went to NAPA Autoparts and got a oil drain plug M22-1.5 and it works BEAUTIFULLY! no leaking air, no thrown code and no nasty rusted nub stickin off the side of my header!!
cost $8
Discussion Starter · #4 ·
chris... so am I... will have it installed next weekend
but for those looking to plug up the bung, I found my receipt.
The plug that I am using right now is from NAPA Autoparts.
Part # 704-1048
So are you guys leaving the egr on, just blocked at the block? Removing the tube from the intake to egr?
I don't want to sound like a complete idiot, but can you guys tell me exactly where on the oem header the EGR is and if I pull the plug on the header and do the plug thing do I have to remove everything,, because here in Wisconsin every car has to go through emissions
well i don't know where in wisconsin you live but i never go through any emmisions here in janesville. All i would like to know is after you remove the egr what are all of you doing to not throw a code? Diablo chip? wedging something in the egr to keep it open or what?
Apparently emissions is a thing in Milwaukee. I took my wife's 2000 hyundai for its first emmissions test in 2001. 45 minutes in line so they could plug in an adapter and sen me on my way 2 minutes later. But any way how do you keep the EGR from throwing a code once you block it off at the header.
i REALLY want to do mine, do i just delete and forget or must i buy a chip as well? is there any other mods along those lines as in resonator removal (which i have done) that i need to do?
1 - 17 of 17 Posts
