Has Ford fixed the rear tire wear/ bouncing problem in the later Focus? I have a 2007 Focus SE, and have already gone through 4 sets of tires, and will need a 5th set soon.
Thanks,
Steve
Thanks,
Steve
I have 2014 focus se and both rear are cupping so ID say no they haven t fixed problem only have 10000 miles on tiresSailor26- I've had this car 4-wheel aligned several times, and the only thing they found was that the rear camber was out of spec, but couldn't be adjusted. I've had the tires balanced at each repair and rotated every 5k miles.
hEaT- When I had the last set of tires put on (at a Ford dealership), I also had a 4-wheel alignment with the paperwork simply stating that it was done. No problems found. These last tires are Uniroyal Tiger Paw Touring, 195/R60/15, 32 PSI. The car came with BFG Radial T/A's, rated at 40,000 miles, but at less than 20,000 had cords showing.
I'm looking at a new 2015 Focus now, and don't want to go through these same problems. I've been assured that they have fixed the problems, but that's coming from the salesman. I am keeping the '07, and would like to get this problem fixed on it, even if it requires new adjustable control arms.
Thanks for your help.
