1 - 7 of 7 Posts
ok i currently have stock 16"'s on my zx3 with 205-50-r16 tires the fronts rub on full lock, i am going to get 17" rims is there anything that can stop these from rubbing why do the 16"'s rub please help.
Ho, ho, ho... Green Giant
rubbing? is ur suspension stock.
only thing i can say is to make sure the offset of your new wheel is 42-49mm. i'd also recommend a 215/40/17 tire. little smaller diameter, but more width for contact patch.
Mike
Don't Call Me Gaga!
The Focus comes stock with a little "friendly interference" with the fender liner at full lock when equipped with the factor 16" wheel/tire combo.
Most people don't notice it though... Is yours worse than usual? Where is the rubbing at?
Don't Call Me Gaga!
Most likely... but a little fender liner interference at full lock is not a problem.... straight line rubbing or fender rubbing would be a much bigger problem.
1 - 7 of 7 Posts
