started tearing engine apart putting bigger valves, intake went from 33 1/2 to 34mm, exhaust went from 28 to 29mm, changed pistons je 11 to 1 compression, eagle connecting rods and i went from 431 intake cam loup and 10% duration increase, exhaust cam went from 380 to 400 and 10% duration increase,with crower valves springs and retainers, focus central cat illiminator pipe and aem adjustable cam gear, just wondering what else i should do and maybe a estimate of wheel horsepower after i am done.
thank djr
Well for one this should be in the zetec forum.
What other mods do you have done to your car?
What brand of cams are you using?
What is done to the cylinder head besides larger valves and what valves are they by the way?
what intake
what T/B
what exh
what did you do for tuning
how did you change the duration of the cams
what work was done to the head
tom
Discussion Starter #4
aem coldair intake,stock tb,cams are custom through web cams,valves are through manley,far as tunins i dont know anybody who can tun the svt in cali,running a magnam flow exhaust with down pipe. thank djr
man this is like the third naturally aspriated errr aspiration of its kind that you moved over, lol
