Thanks a lot and... what happen with your duratec im?I will make a list tomorrow
We should have the final ones out soonThanks a lot and... what happen with your duratec im?
It has to be a focus oil pan and the pan has to match the oil pump and pickup. So it as to be all focus 2.0 stuff or all focus 2.3 stuff you can't mix n match.Do the oil pump, pan, pickup have to be from a 2.0 or will a 2.3 work as well?
YesThanks for the great info. Is the oil port that needs plugging feeding the VCT?
Well HELLO!!! That's pretty stout. Thanks.The rev limiter was at 9k
Its not a 2.5 crank. We are using a balanced 2.3 ranger crankIs that 2.5 crank forged?
No, the 2.5 is a longer stroke.is the stroke the same in the 2.3 and 2.5?
did you key the balancer pulley?
did you mod the timing chain tensioner for high rpm use?
The main journals are the same and the rod journals are different. you can put a 2.3 crank in a 2.5 block or a 2.5 crank in a 2.3 block with the right piston rod combo.I thought 2.5 crank & 2.3 crank where different? I know rods are. But to get it to stroke from 2.3 to 2.5 I was thinking crank & rods.
Can you elaborate on this?The main journals are the same and the rod journals are different. you can put a 2.3 crank in a 2.5 block or a 2.5 crank in a 2.3 block with the right piston rod combo.
