1 - 9 of 9 Posts
i have a automatic trans ,well i got a nut stuck between the trans and the engine,well got the nut out and the plate thats in there .its not the teeth but this cage like thing ,and what does it
do.maybe this will help ,on the plate ,its not the teeth that go to the gears ,but the inner ring of the plate. i have pix ,PLEASE HELP
I think what your refering to is the sensor ring for the crank position sensor??? I think it is positioned on the flywheel.
What is it that you need to know about it??? and what is the nut you got stuck? is it the torque convertor nut? were you taking it out for some reason?
without it, your car wont run. it determines when to fire the sparkplugs, and when to fire the injectors. It basically sends a signal to your pcm telling it where the pistons are in there stoke.
Discussion Starter · #9 ·
thank you all for the help ,i just order a new plate, so i'll be doing that next week. thank again, bros. peace sho tm
1 - 9 of 9 Posts
